Fork brake lugs need cutting back !!!!
steve.w
#16 PostAuthor: steve.w » Thu Feb 23, 2012 12:42 pm
just take 4mm off with an angle grinder .. thats wot i did .. just need a good steady hand mate :wink:
#17 PostAuthor: Rich » Thu Feb 23, 2012 7:39 pm
Revision - I would mill loads off that if I was you!!
the wood work one has the wrong cutting angles. The HSS ones may grab and self feed - apart from that £75 for a one off job is a bit much.
I assume you are going to mount the adaptor plate on the outside.
If you are good with a file and marking out then you could always just cut a bit off and file it parallel to the other lug. If you have a nice flat piece of steel clamp the fork leg to it, so the tops of the mounts are parallel to the plate, clamp another piece of steel to the plate which is the same height as the lugs and use that as a guide to file to.
jimmock
#18 PostAuthor: jimmock » Fri Feb 24, 2012 6:48 pm
Personally I WOULD NOT CONSIDER such an act.
However if you are hell bent on going ahead I think it has to be a job for a machine shop with a milling machine.
Jimmock.
Jimmock. :wnkr
I hate people I don't like !
Z1parR
#19 PostAuthor: Z1parR » Fri Feb 24, 2012 6:58 pm
It'll be fine , what's the worst that can happen :wink:
0172 . Geoff Parr
KeithZ1R
#20 PostAuthor: KeithZ1R » Fri Feb 24, 2012 7:57 pm
FFS Mark Ive got a Mill head its a bit far to come though :)
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
