useing valve shim tool on inlet[sorted]
zman
#16 PostAuthor: zman » Sat Apr 21, 2012 7:59 pm
im thinking cams.its a thought i had today after about 6hrs
im going to check them tommorow
keep thoses wheels turning
#17 PostAuthor: z1bman » Sat Apr 21, 2012 8:08 pm
when the tool is correctly positioned it does not hold the valve fully open. when you turn the crank so the edge of the bucket is located on to the heel of the tool the valve should be a few degrees of its maximum lift
#18 PostAuthor: z1bman » Sat Apr 21, 2012 8:14 pm
if the engine turns over ok without the valve tool inserted it must be a problem with the tool. have you measured how much of the valve stem is above the collets. have you done any work to the valves or seats?
zman
#19 PostAuthor: zman » Sat Apr 21, 2012 8:21 pm
have put in new valves and new seats cut.
exshausts need reshiming but not to far out and one off the in lets do not need changing
zman
#20 PostAuthor: zman » Sun Apr 22, 2012 11:57 am
all sorted.It seams what i could feel was the chain getting abit tight and not piston hitting valve. :oops: :oops:
BETTER SAFE THAN SORRY
at least i kept you entertained :)
