Fuel problems
PAULJAC47
#16 PostAuthor: PAULJAC47 » Mon Apr 30, 2012 7:51 pm
Paul, will it start on full choke?
#17 PostAuthor: paul doran » Mon Apr 30, 2012 7:56 pm
it wont start on any kind of choke
they are CV carbs
float bowls are full but no petrol getting to the cyclinders
#18 PostAuthor: z1bman » Mon Apr 30, 2012 8:19 pm
are the breather pipes clear. have you made sure the camshafts are fitted in the right place
PAULJAC47
#19 PostAuthor: PAULJAC47 » Mon Apr 30, 2012 9:12 pm
Paul, as they are CV carbs one trick to try is to blow gently into the carb breather pipe this can get fuel moving into the system,then hit the starter with no choke,i had a Gs1000g with a blocked choke pickup this method would always get the bike started...Cheers Paul J
prowlerz1
#20 PostAuthor: prowlerz1 » Mon Apr 30, 2012 9:23 pm
just a thought but check that the slides are fitted correctly and have not turned in the bodies,, also that there are no holes in the diaphragms
73 z1 green
73 z1 brown
74 z1a brown
75 z1b red
75 z1b blue
76 z900 green
77 z1000 black
Zrx1200r
