carbs
PaulMceleney
Chunks
#16 PostAuthor: PaulMceleney » Sun May 06, 2012 6:34 pm
rich i was using these carbs but the jetting was wrong and there was no leaks i swaped every thing the float, washer, float valve ,what o rings do you mean i do not understand when you say fuel rail. Also the fuel will come out of side as well there hole on the side thats ment to be there i have fitted a new high flow pingel fuel tap i was using a standard tap before
#17 PostAuthor: Rich » Mon May 07, 2012 6:39 am
Your fuel comes from the tap to the T piece in the centre of the carbs, then flows through the inner carbs delivering fuel to them and then onwards to the two outer carbs by aluminium link pieces. The tubes linking 1&2 and 2&3 plus the centre t piece all have 0-rings on them which are prone to dry out and shrink if left.
If you have swapped everything and the leaking still persists then I would not be expecting the valve to cause it.
If a carb does flood on smoothbores, unless the gasket leaks, it is usually not noticed until the plug cuts out or it starts pouring out of the venturi as the fuel flows straight into the engine.
PaulMceleney
Chunks
#18 PostAuthor: PaulMceleney » Mon May 07, 2012 8:03 am
rich so you think if i fit new o rings this should cure this problem, because i was not convinced it was the valves myself but did not know what else it could be, it must be something like the o rings because it was ok before
#19 PostAuthor: Rich » Tue May 08, 2012 2:54 pm
Put some fuel in off the bike and see where it is leaking from.
