SET OF CAM CAPS Z900/1000
I believe I have a set of caps from a Z1000A2 head.
I will check tomorrow lunch time and send you a text.
Adrian
Adrian
- Ginger Bear
Pigford wrote:Cheers Mr Puffin - me bid is in
No Problem good to be able to help
By the way same seller has a set of cam shell bearingslisted
Ginger Bear wrote:Just like buses eh Piggy......... Non for ages then two come along at once.
Seems to be allways the case
Glad you got them. Fingers crossed you can use them.
Once I have some shells - I'll remove the valves and set it up with the cams & check they turn by hand. I will also visually check clearance by eye in a dim room with a torch
Sounds stupid, but you can see any gaps by the light
These bikes are so old now, 99% of them are running with excessive cam clearances - so as long as they ain't tight - should be OK
Obviously, if the bike runs noisy then I'd have to do the plastigauge bit
- Ginger Bear
Piggy, I was watching these for meself.
http://www.ebay.co.uk/itm/380491805249? ... 1423.l2649
Let me know if you plan to bid on 'em.
