Dave,I have a set of adjusters and the spindle if you want to borrow them for a pattern.
PM for more details.
Davida box section swingarm z1000?
- london calling
Hi Jack, thanks for the offer, if you could send a photo of the spindle then that would be great. Where i work there are a couple of really good toolmakers who can make me a replica from the one eccentric I have, the only thing thats got them confused is where the keyways are cut on the spindle, and i guess you have 2 loose keys you have to insert to lock the rear spindle up?dave
- london calling
- london calling
- london calling
1964davef wrote:trying to "pm" you getting the following error....
Ran into problems sending Mail. Response: 450 4.7.1 Error: too much mail from 92.61.146.171
DEBUG MODE
Line : 143
File : smtp.php
is it me or a hardware problem???????????????
Its not you, Its the Forum. When Internet is busy, this message pops up. Ocassionally the Webbsite locks up.
just a quick update.. received helpfull photos from jack aka "london calling" and got one adjuster machined up to match. To keep costs down i picked up a rear spindle from a zzr600 and got two keyways machined into the spindle. Next step is to strip the paint from the swingarm, get it recoated and ask image works to do me some DAVIDA MOTO decals to finish it off. Have a look at the photos below--once again thanks for the help.dave
Re: Davida box section swingarm z1000?
Good result, looks a very neat job
Some 6mm flat plate with 2 bolts or bar welded in, so they locate in the adjusters should do the trick.
1964davef wrote: i guess theres some sort of tool required to adjust the chain -locating in one of the 3 holes in the eccentric?
Wots up DOHC
Users browsing this forum: doebag and 58 guests
