Z1000 Shaft Coils
compo z1r
st coils
#16 PostAuthor: compo z1r » Sat Mar 23, 2013 8:57 am
there mounted under the rail not above :wink:
THE ORIGINAL TARMAC TERRORIST
Z1OC # 886 till 2030
Z1parR
#17 PostAuthor: Z1parR » Sat Mar 23, 2013 10:33 am
Rich wrote:one of them also looks to be a suzuki coil
You could well be right there Rich :oops:
I do apologise Nige , i've given you bum information regarding bolt centres .
Just measured coil mounting brackets on the frame and they're 40mm between centres .
I see what you mean now that the coils must resemble a brockwurst as there is only 60mm across the framr to fit the two coils into .
In my defence the coils came in a big box with loads of ST bits :oops:
Please disregard four previous posts worth of nonsense :lol:
0172 . Geoff Parr
Z1parR
#18 PostAuthor: Z1parR » Sat Mar 23, 2013 8:57 pm
Looking at that ST picture from compo it appears to show the coils mounted outwards and not inboard of the frame rails , any ST owners confirm this ?
0172 . Geoff Parr
nigel bessant
#19 PostAuthor: nigel bessant » Sat Mar 23, 2013 9:49 pm
The tank must have a cut away to compensate for the coils if they are mounted outside.. Gonna have to relocate the coils somehow then.
nigel bessant
#20 PostAuthor: nigel bessant » Sun Mar 24, 2013 4:01 pm
Much thanks to Z1parR for solving the riddle. Cheers Geoff.
