Z1000 help needed!
#16 PostAuthor: Rich » Fri Jul 07, 2006 5:17 am
"It measures as 1.25 narrower and on a 160 that can make the difference between touching and not touching the tyre"
If you want to throw your toys out of the pram that's up to you, but the above quote is yours - all I am saying to the people who have asked is that you don't save lots of room with a 530 as there is very little difference in the chain width and if they do go that way for that reason alone they would probably be disappointed.
debben1
#17 PostAuthor: debben1 » Fri Jul 07, 2006 10:58 am
I thought I would add my own experiences with wider wheels as I originally fitted a 3.5 inch rim with 130/18 tyre and ran the stock 630 set up with no modifications to the chain line, this looked much wider than the stock rim with 130/18 tyre and greatly improved handling, I was able wear the tyre to the edge which meant better stability and tyre wear (if the tyre is oversize the side of the tyre is pulled in and only the center section of the tread makes contact even when the bike is leant right over, this gives less contact area and greater wear in the middle as well as vague handling ).I recently converted my own bike to 530 set up and a 180/17 tyre on a 5.5 inch wide rim. I fitted the 5/8 offset front sprocket (15mm) and then rebuilt the rear wheel rim 15mm offset towards the disc side and then moved the hub 15mm to the chain side to re-align the wheels, the chain line has then effectively been moved over 15mm, needed a wider swing arm and to change the rear brake set up as the disc is further inboard. I also had to move the rear shocks 10mm out top and bottom, the outer cover needed some modification and I had to remove the lower footrest stud lock nut, but wheels and chain alignment are correct and no tyre cutting required. The 530 chain exceeds the required demands and is less expensive than the 630 which helps towards the cost of the billet offset sprocket.
debben1
#18 PostAuthor: debben1 » Fri Jul 07, 2006 11:06 am
picture of the back end of my bike with the 5.5 inch rim and 5/8 " offset chain line
http://www.debben.co.uk/z1b900.jpg
offet sprockets available from
http://www.debben.co.uk/acatalog/z1000.html
Regards, Steve
#19 PostAuthor: Pigford » Fri Jul 07, 2006 5:59 pm
Best u all listen to Steve D... My Z1000's got a 630 chain, but i got it with it fitted, and its a bit OTT, but its on there, works OK, so it stays!!! My rear end (Oh vicar) is a 180/55x17 with a JMC & a nice billet offset drive sprocket.. from DEBBENS... cool!!!
iancr900
#20 PostAuthor: iancr900 » Sat Jul 08, 2006 9:22 pm
[quote]Quote: from spiny on 5:59 pm on July 3, 2006
Hayabusa for example which runs a 530, it's lighter by about three and a half pounds
does that count towards unspung weight and gyroscopic effect?
#21 PostAuthor: Rich » Sun Jul 09, 2006 1:17 pm
Ian - yes most of it does count to unsprung weight.
Gyroscopic effect not so much, as it is a precession of mass x radius squared, which is why scooters are so quick to steer the gyroscopic effect is smaller due to the little radius of the wheel.
It also affects chain tension with the increased centrifugal force throwing the chain further out on the sprocket as you go faster putting more tension on the chain.
If you want the specs for DID chains go here
http://www.didchain.com/specs.htm
please remember it takes 120 links of a 530 for the same length as 100 of a 630.
Padders
#22 PostAuthor: Padders » Sun Jul 09, 2006 4:30 pm
Rich, you took the words right out of my mouth!
#23 PostAuthor: Pigford » Sun Jul 09, 2006 5:45 pm
Rich, thats a very impressive technical reply..... and the DID chain 'link' (JOKE..tee hee) is interesting....!? To be honest tho' all this discussion/bull about chain sizes effecting performance of a Zed is irrelavent, if it was on a racing 50cc bike, maybe, but propotionally, a kg here or there won't make much difference on a big old Zed!!! Try belt drive, much more sense!
Big John
#24 PostAuthor: Big John » Sun Jul 09, 2006 7:23 pm
You'd have even less chance of fitting a belt drive looking at the width of them.
#25 PostAuthor: Rich » Mon Jul 10, 2006 5:20 am
Pigford - I looked them up when I was thinking about going to 530, RK / Tusbaki? also have specs pages although their according to their specs they aren't as strong (tensile)as DID.
I know what you mean by irrelevant, under 100 bhp (apart from Steves' plus a few others) isn't going to F*** a modern 530 but if you want a sprocket with a slight offset you have to buy a billet one if running 530. My 630 on the harris (chain tension runs from oh my god it's going to fall off to correct!)has only been adjusted once. (admittedly I don't do more than 4k miles a year and it also has a scotoiler) but it's five now!
The best performance mod I could make is to go on a diet, I would loose stones of sprung weight and also be able to get into my leather jeans again!!!
#26 PostAuthor: chrisNI » Mon Jul 10, 2006 10:19 am
Quote: from Rich on 6:17 if they do go that way for that reason alone they would probably be disappointed.
Fair point.
spiny
#27 PostAuthor: spiny » Mon Jul 10, 2006 3:03 pm
If you'd been spending less time swotting up on your DID Technical Specs you'd have noticed it was tools I've been lobbing from the pram not toys.
#28 PostAuthor: Pigford » Mon Jul 10, 2006 5:54 pm
Anyway... " at least mines bigger than yours....!!!!" :biggrin:
#29 PostAuthor: Rich » Mon Jul 10, 2006 6:13 pm
As this highly serious topic is now degenerating into frivolity I'm off to annoy someone else!!!! ;)
P.S. belt drives are for agricultural equipment only - That's why H*****s have them ...............
Users browsing this forum: pjc and 82 guests
