Z1 Petrol tap
wilsonsjw11
Compo1955 wrote:Might be a stupid question, and you`ve probably checked, but is the diameter of the new tap insert the same as the broken one ? or is it thinner and letting petrol run around it.
New lever, as it is without the sleeve, is thinner than the original broken lever by the thickness of the sleeve. Petrol does probably get down the gap caused by the absence of this sleeve.
Basically this new tap is no good without a sleeve.
the early taps are always a pain when it comes to leaking
This guy sells replacement sleeves but they aren't cheap
(scroll down to the very bottom)
http://www.americanclassix.com/kawa_rubber.html
z2.john wrote:the early taps are always a pain when it comes to leaking
Great find, thanks. Looks too thick but the description is spot on.
wilsonsjw11
- DogsbolloxofZ1B
wilsonsjw11 wrote:The replacement seals from americanclassix are the best pattern ones available. They stopped them for a while but it's good to see they are back on the market.
Regards
Steve
Sorry a bit late to this discussion. I certainly second the replacement seals from americanclassixs, the ones from German supplier were shite.
wilsonsjw11
Users browsing this forum: No registered users and 139 guests
