Electrics
z1000puddin
#16 PostAuthor: z1000puddin » Sun Jan 19, 2014 10:51 pm
Pull the clutch in & try it :D
I had a z1000 ltd US model which had the same symptoms - without thinking I pulled the clutch while trying to start it & away it went !!
Zed til Dead
DavidZ1R
Electrics result.
#17 PostAuthor: DavidZ1R » Mon Jan 20, 2014 7:25 pm
Result!
Checked the pick up pulse, all ok, decided to see if Z Power had a igniter I could borrow, they had phew, anyway, connected the borrowed item up but let it dangle on the exhaust rather then bolt it on, gave it a spin, result good spark :D , it must be the igniter :?: :idea: then a thought, could the earth not be good enough, so I rigged up a temp earth the the fitted igniter, gave it a turn over and YEEESSSSS a spark, it seems the existing item of pain wasnt picking up a good enough earth through the powder coated batt box. :D
Next step fuel up the bugger, next weekend.
Many thanks guys for all the help and advice given, that what is tops about this forum. :lol:
steve bowdler
#18 PostAuthor: steve bowdler » Mon Jan 20, 2014 9:32 pm
z1000puddin wrote:Pull the clutch in & try it :D
When I first bought my Zed the guy said thr electric start did not work , yip pulled clutch in away it fired , had a few quid off for this fault :lol:
Users browsing this forum: skinnyZED and 58 guests
