Z1R Rear Axle Nut
KWACKERZ1
#16 PostAuthor: KWACKERZ1 » Thu Mar 13, 2014 10:28 am
Fred,
Just picking up on what you said, about the spindle not being long enough with the dresda fitted, i have fitted a number of dresda's and never had a problem with the standard spindle fitting!
Might be worth a double check everything is together properly and in line.
Fred the Zed
#17 PostAuthor: Fred the Zed » Sat Mar 15, 2014 9:19 am
KWACKERZ1 wrote:Fred,
Hmmmm. Good idea.
Fred
Paid Up Member
Redbeard
#18 PostAuthor: Redbeard » Sat Mar 15, 2014 9:25 am
Fred could you use a thicker washer between swingarm and nut to make up the gap? Mine was the same with the Dresda, the hole for the clip is just out.
Users browsing this forum: No registered users and 140 guests
