charging issue now fixed
Mark Tiller
#16 PostAuthor: Mark Tiller » Fri Apr 18, 2014 5:52 pm
z1bman wrote:was it garn who suggested the brown wire ?? :( :(
Mucho apologies, it is you who is the genius!!! I have changed it, ill buy you a beer sometime to restore your dented pride
seriously...thanks for the suggestion
07962421462
Mark Tiller
#17 PostAuthor: Mark Tiller » Sat Apr 19, 2014 4:40 pm
so...with the wired George mod on and another switched live run down from the headlight to the 4 plug miniloom under the sidepanel took it out for a spin to warm it up, and I see this across the battery...
13v/lights on@tickover then @4000rpm with lights still on around 15v, better but not what I would expect
https://www.youtube.com/watch?v=ZcD3-Oqowyc
:boom
im stumped, anybody got any further advice?
07962421462
Mark Tiller
#18 PostAuthor: Mark Tiller » Sun Apr 20, 2014 7:20 am
Gordon one of the facebookers pointed me towards this link for a fault finding flow chart
https://www.electrosport.com/media/pdf/ ... iagram.pdf
07962421462
#19 PostAuthor: Al » Sun Apr 20, 2014 9:20 am
Has it got one of the encapsulated high output alternators fitted?
#20 PostAuthor: chrisu » Sun Apr 20, 2014 12:15 pm
mark,
out of interest check the 3 yellow wires individually. you should be getting no more than 6v off each of them.
failing that if you want to try another regulator let me know and you can try the one off my Z1R
Mark Tiller
#21 PostAuthor: Mark Tiller » Sun Apr 20, 2014 2:14 pm
Following z1bmans suggestions and that flow chart I attacked the loom with gusto, cleaning every block connector, cleaned the earth connections up, it seems OK now 14.7v at 5000, test ride when I can straighten up again,
thanks for the offer chris, very kind, I was starting to run out of ideas.
I can really recommend the Wired George, starting is much better.
07962421462
KeithZ1R
#22 PostAuthor: KeithZ1R » Tue Apr 22, 2014 8:53 am
Mark Tiller wrote:Gordon one of the facebookers pointed me towards this link for a fault finding flow chart
Im reasonably competent wiv electrics but this document is a mine of useful information and pointed me to a good result this weekend with an itinerant Z1R that would give no more than 12.5v with full load , do yourself a favour guys and download it :up
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
Users browsing this forum: No registered users and 176 guests
