Steve,
I recently rebulit the top end of my J installing a Wiseco big bore kit. I an earlier thread you sorted out my confusion on whether I retained the various O rings when using this gasket and you correctly said "no"
However Since the engine has been assembled there has been a fine mist of oil around the bore which I originally thougth was just a leak from a cam plug but it seems to be more general than that, around the cylinder head joint. Given that the head is properly torqued (well the 12mm anyway, the 2 end 6mm bolts I think have BU***d threads). Could the leakage be that the 2 6mm bolts are not tightened down or for some other reason? One thing I note is that you seem to suggest filling in the cam tunnel O ring groove. I have not done so. Could that be the problem?
Help me sort out my head?????
Users browsing this forum: No registered users and 106 guests
