The cheapest option IF needed is to get a replacement, second hand barrel
Just a few options for you wayne
cheers freddy
buzzard wrote:Wayne, I did say it would smoke and I advised you it would need a rebore. If you remember number 2 cylinder had damage to bore from the metal F.O.D incident, also number 1 cylinder had a bad score along the length of the bore and number 4 cylinder had a bad rust/ water stain mark aswell. You need to rebore to 0.50 mm oversize pistons and if your doing that the guides which were badly worn as I pointed out at the time will also need replacing, because it will smoke from there especially when you start it from cold after the bike has been standing for a few days and it will only get worse. Personally myself I'd bore it out to 1015cc. Buzzard.
Users browsing this forum: No registered users and 154 guests
