no spark
#16 PostAuthor: ZedHead » Wed Aug 20, 2014 9:15 am
z1bman wrote:this is a mk11 engine which it later than yours but the earth wire attaches to the engine about 2 inches below the rear top engine mounting on the right hand side. small 6mm threaded hole in the crank case
Wow! that is a shiny engine :drool :drool
#17 PostAuthor: ZedHead » Wed Aug 20, 2014 9:34 am
"yea connected the earth to the correct place,still no spark,there seems to be nothing to the coils,tried the old coils still no joy,connected a live straight to the live coil wires and still no spark,its got to be something simple,ive cleaned all the coloured plugs checked all connections".
If you have fed direct 12v to the coils and still no spark, it can only be a bad earth or no pulse from the points. Try exciting one of the coils by disconnecting it's points feed and taking the coil wire to to earth and off again . If you get a spark when the temporary earth is lifted you know to look at the points area.
#18 PostAuthor: z1bman » Wed Aug 20, 2014 9:37 am
if you put a direct feed to the coils you should have a spark the only other cause is you have not wired the points & condensers correctly with the fibre washer not insulating the connection? you will still need to trace why you Havant got a live feed to the coils by doing a resistance check between the coil wires & the engine stop switch
#19 PostAuthor: chrisu » Wed Aug 20, 2014 10:17 am
mk2 - could be pickups or ic ignitor - had this problem on my old H years ago - new pickups needed
#20 PostAuthor: z1bman » Wed Aug 20, 2014 11:07 am
chrisu wrote:mk2 - could be pickups or ic ignitor - had this problem on my old H years ago - new pickups needed
chrisu its a z900a4 with standard points & condensers :wink: :wink:
#21 PostAuthor: z1bman » Wed Aug 20, 2014 11:19 am
this is how the points should be wired
keith mayall
#22 PostAuthor: keith mayall » Wed Aug 20, 2014 11:56 am
z1bman wrote:this is how the points should be wired
that's how they wired,,just seems no power getting to the coils.keiths comin tomorrow to have a look.will let you know how it goes.
#23 PostAuthor: chrisu » Wed Aug 20, 2014 12:06 pm
doh - that'll teach me to read the whole thread........... :oops:
#24 PostAuthor: z1bman » Wed Aug 20, 2014 12:41 pm
check the power in to the r/h switch to the yellow with red tracer wire = 12 volts also the brown = 12 volts
Lee McEvoy
#25 PostAuthor: Lee McEvoy » Wed Aug 20, 2014 8:39 pm
Keith,
Have you got steel fixings or aluminium on the points casing? I had a problem where I. Could not get a spark, put one steel in the casing and it was fine..
Just a thought
Lee
keith mayall
#26 PostAuthor: keith mayall » Thu Aug 21, 2014 11:28 am
Lee McEvoy wrote:Keith,
Just a thought steel,fixings,no power to the coils,got a new loom coming and keiths comin over to look at it this afternoon.cheers
Lee
keith mayall
#27 PostAuthor: keith mayall » Thu Aug 21, 2014 3:20 pm
cheers everyone,it was a few bad conections .sorted thanks to keith z1r
DavidZ1R
#28 PostAuthor: DavidZ1R » Thu Aug 21, 2014 4:07 pm
He's a top man is that Keith chap :D
#29 PostAuthor: Pigford » Thu Aug 21, 2014 4:09 pm
DavidZ1R wrote:He's a top man is that Keith chap :D
Don't give him too much praise :roll: .....it's bad for him
