Dyna S
Hi, Glad to hear my trick worked,dont worry too much if you cant see the advance mark i have had the same on a set ,i just set to the F and leave my strobe running by taping the trigger on aim at the unit and just make sure it advances,always seem to run fine...Paul J
wilsonsjw11
Steve i never bother with the static set up.you need four pairs of hands,just get the bike running,get your strobe to stay on,fix it so it points at the timing marks,and tap the plate round with a screwdriver and small hammer,with the three screws loosish,till the F mark lines up,tighten up the three screws and just make sure it advances to where the bob weights start,job done...Always set mine up like that and no probs..Cheers Paul J
wilsonsjw11
Paul,
Set up as per your instructions and spot on.
I cannot believe the F**k about with the static timing as per the instructions and when you put the strobe on it its a mile out anyway.
Regarding the advance mark on the early(72/73) advancer there is no mark.The owners manual describes it as "at 2,900-3100rpm,the timing advancer changes enough so the timing mark and the pin on the timing advancer should be aligned at this speed or higher"
Regards
Steve
Regards
Steve
wilsonsjw11 wrote:Paul,
Regards
Steve
Glad to hear that Steve.....Cheers Paul J
Users browsing this forum: No registered users and 154 guests
