warren3200gt wrote:Screw the idle in until it will lock the balance them all again.
1977 Z1000 A1 Carbs - Carb info
Re: 1977 Z1000 A1 Carbs - Carb info
Now you have said it out loud it makes sense . . . I think when you have 3 in balance and one rogue one you tend to focus on that one and try and bring in in line with the other 3. The approach you outline is to get the dodgy one locked out and bring the other 3 in line. I'll let you know how I get on, thanks for stating what might be the obvious to most.
Guy
GuyHughes wrote:Does anyone know what the vacuum gauge settings are for a Z1000 A1 1977 with vm26ss carbs are as a standard build, i.e. Standard pipes, needle jets, air filters, etc.
Off top of my head 28mm MG +/- 2mm.
