Carb tuning
#16 PostAuthor: ADRIAN H » Thu Jan 01, 2015 7:08 pm
baz wrote:
Pigford wrote:
baz wrote:i always find this way the best at setting carbs up .........
remove the exhaust system from the head and start the engine
when warmed up set the tick over slightly higher than norm
turn the garage lights out and adj the mixture screws so that all
flames are the same length and a nice light blue colour.
Its like doing four colour tunes in one :D
No wonder you're half deaf (as well as daft) :lol:
what did you say :D
glad I do nt live next door. :lol: :lol: :lol:
510racer
#17 PostAuthor: 510racer » Sun Jan 04, 2015 3:40 am
nw66 wrote:I had a set of 29's on my 900 and had the same issue its running a bit weak where the hole is I adjusted the needle height to add more fuel and hey presto I got it running pretty much spot on. I did get it on a dyno though to get it as good as we could. Hope this helps :up
I raised the needle heights then played around with the air screws again it appears to have helped slightly but the issue is still there.
I don't suppose anyone knows someone in Australia who can tune these for me??? :lol:
