Rocker Cover Removal
Well tonight I got the pesky thing off, I think the previous American owner used a whole tube of silicone on it, I will check tomorrow the valve clearances, looking in the manual the special tool looks different to the valve clearance guide
1981 KZ1000 K1 LTD
Farm Boy with an O Level in Metalwork and not much else.
Everything in Sussex is a She, Except Tom Cat and She`s a He.
- mick znone
- mick znone
- Ginger Bear
zorded wrote:Replied in shim thread.
Might be a good idea to remove the oil filter if not the sump as that nasty stuff has a habit of drawing to the oil feed pickup below the oil pump!
Are you ready for us to send Jim the 'traveling mechanic' yet?
He has a boat full of seamen that he smokes about in!![]()
Only if hes bringing an Alfa exhaust to fit, then he might as well do the sump job as well
1981 KZ1000 K1 LTD
The rocker cover came off surprisingly easy although I found another stripped thread, after reading Pigfords post on some American forum I found myself on one evening I voted for buying 1/4 allen bolts for the two stripped ones, it worked a treat and with some thinner shims it all went back together nicely.
1981 KZ1000 K1 LTD
Users browsing this forum: zapo and 70 guests
