wont ffin start
keith mayall
#16 PostAuthor: keith mayall » Thu Mar 12, 2015 12:40 pm
Thanks everyone...the new coils where doing nothing.put the old ones on .it runs sweet as a nut.happy now.
PAULJAC47
#17 PostAuthor: PAULJAC47 » Thu Mar 12, 2015 5:38 pm
Thought it was sparking?
#18 PostAuthor: z1bman » Thu Mar 12, 2015 5:56 pm
don't leave the ignition switched on for long periods
#19 PostAuthor: Pigford » Thu Mar 12, 2015 5:58 pm
z1bman wrote:don't leave the ignition switched on for long periods
So how do you ride anywhere decent :cheek
I've seen a few sets of old coils melted due to ignition left on when the bikes been stopped by the kill switch and rider gets distracted :??
RAYZ1
Re: wont ffin start
#20 PostAuthor: RAYZ1 » Thu Mar 12, 2015 6:24 pm
keith mayall wrote:had the carbs cleaned,refurbed.get a spark when contact the points with a driver..seems no fuel as the plugs aint wet...where do I start.getting nothing.
if theres anyone in the north Manchester area willing to check it out would be good.
do you get regular sparks at the plugs when you crank it over on the starter ? if not check you have rubbed off enough of the powder coating to get a good circuiy with the coils, also measure the resistance of the coil through the plug to earth - I think it should be around 5ohm ??, possibly 3 but I stand to be put right as its from memory, check all 12v connections .
keith mayall
#21 PostAuthor: keith mayall » Thu Mar 12, 2015 7:04 pm
PAULJAC47 wrote:Thought it was sparking?
it did a weak one now and then but if I stuck a driver on the points it sparked...I put the old coil back on and the spark was mega...so I put em back on.works fine now.
Users browsing this forum: zapo and 70 guests
