Z550
Bonneville
- Regular Poster
Thanks! I can't believe the bodgery I got away with when I was despatching. I once rode an overheating CX500 home with Sunkist orange squash in the radiator (they didn't sell bottled water in garages back then). When I got home the sugar had caramelised and it smelt like a sweetshop.
Or the time I snapped a throttle cable and rigged the return up instead. Good plan but the return was shorter than the pull so I had a 3K tickover and had to ping the clutch in and out on the motorway...plates were melted by the time I got home.
Z550 A1/A2
Hinckley Bonneville
R1 Anniversary
NSR250R
KR1-S
BSA Bantam
Hinckley Bonneville
R1 Anniversary
NSR250R
KR1-S
BSA Bantam
Bonneville
- Regular Poster
Took it out into the daylight for the first time in 20 years. Still waiting on carb parts so can't run it yet. Exhaust was off a GT550 and the brackets are wrong so I'm welding this weekend.
My master cylinder has a cracked body so I risked one of those £14 Chinese universal ones off E-bay. Not bad but if anyone has an original please let me know. Ta.
Z550 A1/A2
Hinckley Bonneville
R1 Anniversary
NSR250R
KR1-S
BSA Bantam
Hinckley Bonneville
R1 Anniversary
NSR250R
KR1-S
BSA Bantam
Bonneville
- Regular Poster
Bonneville
- Regular Poster
Started up today. Ran lovely once the carbs were balanced and quiet too. Then the oil light came on at tickover.
It goes out off idle but was lingering for longer as the oil warmed. I shut it off and took the cam cover off and plenty of clean oil up there. Bottom end is quiet.....I'm having the sump pan off to look at the pump but any ideas much appreciated.
Z550 A1/A2
Hinckley Bonneville
R1 Anniversary
NSR250R
KR1-S
BSA Bantam
Hinckley Bonneville
R1 Anniversary
NSR250R
KR1-S
BSA Bantam
Bonneville
- Regular Poster
Oil came out piss thin. It's a 10/40 semi-synth and I seem to remember it didn't like that weight 20yrs ago but that could just be my memory being convenient.
Everything looks good inside so I'm going to throw it back together and put a 20w 50 in it.
Video of it running here:-
http://triumphworld.tumblr.com/
Z550 A1/A2
Hinckley Bonneville
R1 Anniversary
NSR250R
KR1-S
BSA Bantam
Hinckley Bonneville
R1 Anniversary
NSR250R
KR1-S
BSA Bantam
Bonneville
- Regular Poster
Yes, I've heard they can be a bit sensistie. Sounds like it carried over to the ephyr 550 as well.
But anyway, I found the problem. This tool managed to omit the big o-ring from the top of the sump pan. The only thing I can think of is that it's the same as the one on the oil filter plate and I threw the original thinking it was from there.
Z550 A1/A2
Hinckley Bonneville
R1 Anniversary
NSR250R
KR1-S
BSA Bantam
Hinckley Bonneville
R1 Anniversary
NSR250R
KR1-S
BSA Bantam
Bonneville
- Regular Poster
Bonneville wrote:Thanks! I can't believe the bodgery I got away with when I was despatching.
I broke the clutch cable on my AP50 once, in Cornwall. I disconnected the rear brake and wrapped the inner cable round the brake pedal to give me a pedal clutch. It got me home ok
That's one hell of a job you're doing there, awesome stuff
Richard
Somewhere, over a rainbow, weigh a pie.
1976 KZ900
1976 KZ900
Bonneville
- Regular Poster
