Dyna coils and MK11 ignition
Taffus
#16 PostAuthor: Taffus » Fri Feb 26, 2016 9:20 am
Just join the red and pink wires.....
KeithZ1R
#17 PostAuthor: KeithZ1R » Fri Feb 26, 2016 10:03 am
There will be some extensive wire replacement and a relay feed going in like the rest of the fleet :lol:
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
Taffus
#18 PostAuthor: Taffus » Fri Feb 26, 2016 10:14 am
That wired george md is very good. I'm tempted for the A4 but it's running really good so I'm a bit reticent to do it.
#19 PostAuthor: chrisu » Fri Feb 26, 2016 11:08 am
If the voltage at the coils is already close to 12v not a lot of point
Taffus
#20 PostAuthor: Taffus » Fri Feb 26, 2016 11:54 am
chrisu wrote:If the voltage at the coils is already close to 12v not a lot of point
True! and it's running fine.......
nicomkii
#21 PostAuthor: nicomkii » Sun Jun 26, 2016 11:33 am
Never been big on electrickery but having a stab at putting a pair of 3ohm Dynas on the MkII. With he below diagram when bypassing the ballast and plumbing in the wires does it matter as to where the wires go i.e. -
For Cylinders 1 & 4 with the red and black feed does the red go to the top of the coil terminal when mounted or to the bottom or ..........& likewise for the coil feeding Cyl 2 & 3.
RGH wrote:3 ohms is the go with Mk11's
Nico
nicomkii
#22 PostAuthor: nicomkii » Mon Jun 27, 2016 11:50 am
Have wired up as per the above diagram, bike turns over but doesn't fire. I take it the diagram is correct ???
If so then I must have the wires all screwed up. I have the dyna green 3ohm coils with the HT leads coming out from on top and facing forward when in frame. With the two red power wires I have them fitted to the 'Top' connector on the Dyna and the Black / Green respectively to the bottom connector when the coils are mounted ?
Really need a profile diagram on the coils rather than the plan ones above. Cheers for any advice
Nico
#23 PostAuthor: Pigford » Mon Jun 27, 2016 6:59 pm
nicomkii wrote:Have wired up as per the above diagram, bike turns over but doesn't fire. I take it the diagram is correct ???
Either swap Black/Green feeds around ------ or the mounting post is shorting the power - the low tension power screws sit very close to mountings!!!
johny brando
#24 PostAuthor: johny brando » Sat Jul 23, 2016 10:53 pm
njwmct wrote:I'm running 3 ohm Green Dynacoils with my standard Mark II ignition.
You need to remove the Ballast Resistor used with the standard MKII coils.
Been running like this for 3 years with no issues.
+1 on the above . I was kindly educated on this point a short while ago on this Forum here (thanks again guys for that ! ) as I have been running MK2 ignition on my 900 with the Std OEM 'near' 4 ohm coils and the Resistor .....'wrongly' still hooked up to them ! I was lucky my coils are still fine & all's good.
nicomkii
#25 PostAuthor: nicomkii » Sun Jul 24, 2016 12:32 pm
All sorted and running well. Only issue I have is that on a cold start up the starter motor appears to 'run on' with a cold start and the motor not running up. Takes a few goes with a bit of choke on these chilly Oz mornings of late and every now and then I get that 'run on' issue with he starter.
Nico
steve.w
#26 PostAuthor: steve.w » Sun Jul 31, 2016 8:42 am
just bought a mk2 its running grey dyna coils with standard ignition
#27 PostAuthor: Pigford » Sun Jul 31, 2016 9:05 am
steve.w wrote:just bought a mk2 its running grey dyna coils with standard ignition
Dunno answer to that - but on me Harris I was running Dyna S with Grey (2.2 Ohm) Dyna coils and one of them fried after a 100 miles :??
Users browsing this forum: Bing [Bot] and 86 guests
