Noisy cam chain
phil churchett
#16 PostAuthor: phil churchett » Wed Dec 06, 2006 7:54 pm
Wear ear plugs, problem solved!
#17 PostAuthor: Pigford » Wed Dec 06, 2006 8:00 pm
Phil, its always best to wear earplugs whenever Paul D's around!
phil churchett
#18 PostAuthor: phil churchett » Wed Dec 06, 2006 8:12 pm
Ah, now i have always found Paul to be a very balanced, fine and up-standing individual.
#19 PostAuthor: Rich » Thu Dec 07, 2006 6:59 pm
Drop it off at christmas Paul, I'll sort it out next year for a very reasonable rate :cool:
Padders
#20 PostAuthor: Padders » Thu Dec 07, 2006 8:26 pm
I have fitted two splitlink camchains in the past and never had any problems. Take your time and there is no reason for it to be any weaker than a normal chain.
Padders
PUM 13
hanskloss
#21 PostAuthor: hanskloss » Fri Dec 08, 2006 12:07 am
Pigford as long as you're using the right tool not a hammer to do the link it's no different to endless one, I've done mine last year when refreshing the top end and am confident reving it right to the redline
DogsbolloxofZ1B
#22 PostAuthor: DogsbolloxofZ1B » Fri Dec 08, 2006 6:36 pm
Just testing my avatar
#23 PostAuthor: Rich » Sat Dec 09, 2006 10:03 am
When the previous owner replaced the tensioner bits, I assume they only replaced the rod - try putting a new spring in the tensioner.
