Top shock mount extensions
Julian_Boolean
Re: Top shock mount extensions
Do you have any of these left and do they fit on a Z1000J
LeeJackson
Julian, I used them on my J, worked perfectly.
I would also take a set from you if you have 2
Many thanks
Gus
Many thanks
Gus
"Set the GRINDER on it"
would the club rack go over the these
They extend the rear shock mounting out by 20mm so if the club rack can open up 20mm each side I don't see why not ?
PUM 451
I will have a set if you have any left or make another batch.
thanks
thanks
5 Sets left
Shocker extensions are now ready
£30 Inc P+P
£30 Inc P+P
PUM 451
Hi
I would like a pair of these if you still have any.
