No spark on 1000J – Fitting Dyna S, advice needed
Re: No spark on 1000J – Fitting Dyna S, advice needed
#16 PostAuthor: ZedHead » Mon Jan 29, 2018 4:47 pm
If it is like this pattern ones are available
Coose
#17 PostAuthor: Coose » Mon Jan 29, 2018 4:48 pm
The switch comes apart easily enough if you're careful. In fact, I had mine apart today to clean it before the rebuilding of my bike commences... :)
#18 PostAuthor: z1bman » Mon Jan 29, 2018 4:58 pm
does yours look like this? or has it got the longer lock stem ?
www.ebay.co.uk/itm/Kawasaki-Z1000-J-Pol ... 007239123&
rickm
#19 PostAuthor: rickm » Mon Jan 29, 2018 5:19 pm
z1bman wrote:does yours look like this? or has it got the longer lock stem ?
http://www.ebay.co.uk/itm/Kawasaki-Z100 ... 007239123&
Mine has the longer stem with the steering lock bolt that comes out vertically from the bottom.
It has a similar wiring set-up as that pictured in post #16 above.
H2B GPZ900R
rickm
#20 PostAuthor: rickm » Mon Jan 29, 2018 5:24 pm
Coose wrote:The switch comes apart easily enough if you're careful. In fact, I had mine apart today to clean it before the rebuilding of my bike commences... :)
This would be my first choice, but I just wanted to weigh-up my options before breaking the thing into 1000 pieces!
H2B GPZ900R
rickm
#21 PostAuthor: rickm » Mon Jan 29, 2018 5:27 pm
ZedHead wrote:If it is like this pattern ones are available
Where is this advertised?
H2B GPZ900R
#22 PostAuthor: ZedHead » Mon Jan 29, 2018 5:36 pm
This looks to have the longer stem.
I agree fixing original should always be your first choice if possible. Even if for no other reason it means keeping all the same keys.
#23 PostAuthor: z1bman » Mon Jan 29, 2018 5:41 pm
i would say its this type with the steering locking pin in the vertical position ?
https://www.ebay.co.uk/itm/Z%C3%BCndsch ... 1438.l2649
rickm
#24 PostAuthor: rickm » Mon Jan 29, 2018 6:25 pm
z1bman wrote:i would say its this type with the steering locking pin in the vertical position ?
Yep, that's it, but I refuse to pay that much for one !
H2B GPZ900R
#25 PostAuthor: ZedHead » Mon Jan 29, 2018 6:40 pm
Maybe try John Browse?
#26 PostAuthor: z1bman » Mon Jan 29, 2018 7:25 pm
Coose
#27 PostAuthor: Coose » Mon Jan 29, 2018 7:28 pm
If yours isn't salvageable it may be worth trying DK as they've broken a few US Js.
rickm
#28 PostAuthor: rickm » Mon Jan 29, 2018 7:53 pm
Seems like mine is not salvageable. It's clearly been butchered in the past, and is never going to go back into any sort of reliable working order.
z1bman wrote:https://www.ebay.co.uk/itm/81-KAWASAKI-KZ1000-KZ-1000-K-OEM-IGNITION-SWITCH-ELECTRICAL/382344434504?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649
This is the bit :up
Might give it a go.
H2B GPZ900R
rickm
#29 PostAuthor: rickm » Sun Feb 11, 2018 1:40 pm
Now bear with me on this please.
Ok, so I bought a new ignition switch from the USA, but still have the same issue. I have a 7 wire switch, US version J.
Checked out the connections in the switch with the key in various positions according to the manual, and everything connects up as it should.
Putting switch in the "on" position connects the white/black power-in lead to a white wire out. With the block in the headlight disconnected there is continuity in the main loom between this white wire and the brown wire coming back into the switch. The brown wire then connects to the yellow/red that goes to the starter button. So, (in theory?) if the white wire has battery power (from the white/black power-in wire), and the white lead has continuity with the brown wire, then the brown wire should have the same 12V battery power (because there's continuity)?
BUT THE BROWN WIRE HAS NO POWER !!
What's going on?
Am I missing something really obvious here?
A few weeks ago the bike ran fine, and then just developed a mis-fire.
H2B GPZ900R
rickm
#30 PostAuthor: rickm » Sun Feb 11, 2018 4:42 pm
Ignore me !
Having checked all the fuses several times before and everything seeming ok, I just checked again as an act of desperation.....
and the feckin' fuse has blown !! :oops:
H2B GPZ900R
Users browsing this forum: No registered users and 93 guests
