wiring problems
Re: wiring problems
#16 PostAuthor: z1bman » Mon Jul 23, 2018 10:37 am
what happens if you put a live feed to the thin black wire on the solenoid?
GinjaDave
Re: wiring problems
#17 PostAuthor: GinjaDave » Mon Jul 23, 2018 2:49 pm
The engine turns over.
Of all the things I've lost I miss my mind the most
Re: wiring problems
#18 PostAuthor: z1bman » Mon Jul 23, 2018 3:06 pm
then your problem is the black wire from the solenoid back to the switch. does the engine turn over if you put a live feed to the black wire that goes into the main harness where all the switch wiring connect? have you done a resistance check on the black wire under the tank to the black wire to the solenoid
GinjaDave
Re: wiring problems
#19 PostAuthor: GinjaDave » Mon Jul 23, 2018 6:01 pm
I connected the black under the tank to the live and the engine turns over, then I dropped the end of the wire that I had put on the battery, it went to earth and the engine turned over. I'm very confused.
Re: wiring problems
#20 PostAuthor: z1bman » Mon Jul 23, 2018 7:37 pm
what colour wires are on your solenoid & what colour wires are they connected to on the harness ?
GinjaDave
Re: wiring problems
#21 PostAuthor: GinjaDave » Tue Jul 24, 2018 12:07 pm
Yellow and black also black both connected to the same colours.
Re: wiring problems
#22 PostAuthor: z1bman » Tue Jul 24, 2018 2:47 pm
GinjaDave wrote:I connected the black under the tank to the live and the engine turns over, then I dropped the end of the wire that I had put on the battery, it went to earth and the engine turned over. I'm very confused.
which end of the wire touched earth? the one connected to the battery or the one connected to the black wire?
GinjaDave
Re: wiring problems
#23 PostAuthor: GinjaDave » Mon Jul 30, 2018 4:51 pm
I've put it on my trailer and taken it to a local bike shop, they will now sort the wiring. Thanks for all of your help and advice.
