Z1000-A1 rear brake master cylinder bleeding
Re: Z1000-A1 rear brake master cylinder bleeding
I'm having similar problems with mine (A1 rear caliper). When i pull the fluid through with my vaccuum pump, air seems to be getting in down the bleed nipple thread. Anyone know of a way of sealing the threads without blocking the oil way at the bottom? The nipple seems quite loose in the thread. Is it a case of machining a new thread?
ChrisB wrote:I'm having similar problems with mine (A1 rear caliper). When i pull the fluid through with my vaccuum pump, air seems to be getting in down the bleed nipple thread. Anyone know of a way of sealing the threads without blocking the oil way at the bottom? The nipple seems quite loose in the thread. Is it a case of machining a new thread?
New nipple maybe ?
I've stumped up for a new seal set which includes a new nipple. I'll give them a service and see if the new nipple is tighter. Are these calipers usually ok to bleed?
I usually tie in the front brake leaver over night to cure the spongy brake feeling
and its worked everytime up to now and ive done a few
A couple of twists of ptfe tape on the nipple thread stops air getting in, my dad taught me this in the late Seventies and i never have a problem with bleeding.
love the ptfe idea kev. Just plumbed an entire central heating system and used yards of it but it STILL didn't occur to me!
Users browsing this forum: No registered users and 114 guests
