Z1a (August 73 build, USA)
Re: Z1a (August 73 build, USA)
put them back in and fit the sprocket carrier. if you can feel movement replace them.
- 8 Valve Mark
Adrian90s wrote:Many thanks...no good for my 73 bike then. Anyone got a 3c-f to swop?
Or I can sell the rim, no rust on the rim...or the bike come to think.
if you NEED the correct dates on your rims adrian, I'd suggest locating them 1st before parting with yours, an a4 owner somewhere will happily snap them up. in the meantime you can use them. unless anorak rash is setting in already
?Re: Z1a (August 73 build, USA)
No Mark, anorak rash defo no!
I think newer dates are worse than no dates.
Will buy stainless rims/spokes which will look very pretty.
Ady
Ady
Hi Adrian
keep your old wheel rim, only replace the spokes and nipples. It's very hard to find a Takasago 303 rear wheel rim in good shape.
It was probably changed in the past because something happened with the original rim...so this one is part of the history of your bike.
As far as the cush drive rubbers are concerned: if the sprocket carrier has about 1 cm of radial play I would replace them, if it's less, keep them, they'll do the job.
Once again thanks Phillipe, will wonder into the garage for 5 mins today and check the cush rubber play, then go to the pub and watch the football.
Cush rubbers next to no free play at all, no damage.
Brake shoes no wear at all but will change, mechanism greased from previous and it looks new inside, Hope the rest of the bike is so well looked after, feeling optimistic.
Happy New year guys
Ady
Happy New year guys
Ady
- 8 Valve Mark
Adrian90s wrote:No Mark, anorak rash defo no!
Ady
that's the spirit ady!! anorak not evident.
Thanks Mark
May take you up on the rim locks, the stems are very rough.
Ady
Ady
