Kz650
Re: Kz650
#16 PostAuthor: ADRIAN H » Fri Mar 29, 2019 11:44 am
Philbike wrote:just thought who would someone go to the trouble of wiring hazards?
If you're going abroad, (especially in France), you need hazards fitted.
Philbike
Re: Kz650
#17 PostAuthor: Philbike » Sat Mar 30, 2019 2:25 pm
Hi,the handle bars must have been changed in the past,all switch wire is on the outside..
The flasher unit is behind the side panel and works.
I can hopefully send some pictures in later,but at the moment I am in the process of
fitting a new camshaft cover gasket which has started to leak after a top half rebuild.
On the plus side the bike ran fine with no smoke on start up, ended up renewing,
New rings
Honed bores
New valve guides
New seals
Replace 3 buckets and one valve.
