Gsxr slabside 29mm carbs
Julian_Boolean
Re: Gsxr slabside 29mm carbs
#16 PostAuthor: Julian_Boolean » Wed Jun 26, 2019 10:42 am
needaz1100r wrote:
Julian_Boolean wrote:They look like the standard GSXR VM29SS carbs, they're 29mm on one side of the slide and 33mm on the other, I can't remember which way round.
They sit in the same rubbers as standard 34mm so I was thinking it was the engine side, but you are right, they narrow a lot at the slide and that's where the 29mm comes from.
On GSXRs RS34s slot straight into the standard rubbers, on my Unitrak head RS34s require a certain amount of pressure to go into the rubbers (a ratchet strap helps a lot)
needaz1100r
#17 PostAuthor: needaz1100r » Fri Jun 28, 2019 6:38 am
I was meaning they go in the 34mm rubbers found on GS1000CVs and later Zed J style heads but not the 26/28mm style rubbers that will be in Mr swirl's head.
Cheers,
Mark.
Users browsing this forum: Google [Bot] and 111 guests
