Carb balancing
needaz1100r
Re: Carb balancing
#16 PostAuthor: needaz1100r » Sun Aug 18, 2019 2:08 pm
crossthread wrote:YAY. IV'E GOT IT . Thanks warren3200gt , good explanation. Of course , the volume in each float bowl will be different because each float will have a different displacement. I know the recommended way to do it , done it many times . I was trying to re-invent the wheel . I gotta disagree with Adrian H though , draining each carb in turn and measuring the volume of the fuel would be easy , and you gotta drain the carb to fit the measuring pipe. Over thinking ? me ? :D :D
As Adrian said, the first carb you drain will also drain, because the float valve will open, the fuel left in the fuel pipe, the others won't. On a twin feed set that would be repeated on one of each pair.
Cheers,
Mark.
Re: Carb balancing
#17 PostAuthor: warren3200gt » Sun Aug 18, 2019 2:47 pm
Easily overcome though, surely? Drain one of the pair, measure the other. Then repeat in reverse. So the theory is good bar the float displacement issue. It would just become more labourious than doing it the wet method.
