Z1000J Starter Clutch - Flywheel
Re: Z1000J Starter Clutch - Flywheel
#16 PostAuthor: Al » Mon Mar 29, 2021 8:40 pm
Outer Diameter: 104mm Inner diameter: 38mm Thickness through hole: 20mm
These are the dimensions for the GO3 Stator generator. If yours match,... bingo. They have 6 listed in stock.
ZPOWER are showing none in stock of either the correct GO3 or the incorrect GO1 and those pictures look like the old; high output, encapsulated ones that Electrex World used to do but i believe may have now discontinued.
Electrex phone staff are super helpful and know their stuff. As you say give them a ring. I wouldnt bother to point out the mistake though as the implication of them having done something wrong by myself and others was taken as less than helpful!
Its definately not a GO9 and i didnt help by calling the rotor a GO3 previously when i should have said RO3.
RO3 goes with GO3.
Dont know how youre starter motor is doing but they do a fantastic replacement brush carrier plate complete with brushes for the four and two brush versions.
Mine hapened to be this one and for £21 you could not make the box it comes in.
https://www.electrexworld.co.uk/acatalo ... ml#SID=720
Users browsing this forum: No registered users and 155 guests
