Electrical fault or fuse ?
Re: Electrical fault or fuse ?
Yes. The glass fuses all looked intact. But thought I’d just swap a few around & it shown one had blown. Do I need to get hold of the glass style fuses. Been to few places today but no one seems to stock them.
For the correct glass fuses try Vehicle Wiring Products based at 9 Buxton Court, Manners Industrial Estate, Ilkeston.
You need the 25mm long version in 20A and 10A.
Great. Nice & local. Mine have 30A. Not 20A. Is the correct 20?
According to the KZ1000-A1 owners manual and the Haynes workshop book, the fuses are 1 x 20 amp and 2 x 10 amp respectively. (25mm long)
The 20 amp is in-line with the white wires.
1 x 10 amp fuse is in-line with the red/blue and brown/white wires.
1 x 10 amp fuse is in-line with blue and blue/white wires.
Very helpful guys at Vehicle Wiring Products, and hopefully pretty local to you. Pick up a copy of their catalogues if you call in person, it shows the extensive range of electrical products they hold.
Thanks for the info. All ordered. Mine was set up with x2 30A & 3x 10A
