Another 650 for me
MDM
Re: Another 650 for me
#16 PostAuthor: MDM » Mon Oct 30, 2023 4:32 pm
Slowly but surely I'm finding more issues, and also overcoming a few along the way too. I've done very little, constructively, just the odd bit of tinkering here and there, just five or ten minutes at a time and sussing out the extra bits that I need to source.
It now has flat drag bars fitted, a new throttle cable and the calipers have been removed and the master cylinder will be replaced by one from a 600 Bandit so that the reservoir sits flat, rather than at an angle as per the previous one (which must've been from a bike with clip-on type bars, I'm thinking GSX600F 'Teapot').
The rear master cylinder is toast, but I think I have a suitable motocross type one that'd do the trick (CRF250 or 450 I think).
Z650/1100 turbo, GPz750 rolling resto, Z650 restomod
#17 PostAuthor: warren3200gt » Mon Oct 30, 2023 4:37 pm
Does it run? Have you done a compression test or engine work on it?
MDM
#18 PostAuthor: MDM » Tue Nov 07, 2023 3:29 pm
I've not had it running yet, or done a compression test but have turned it over on the kickstarter, so there is some compression... 'some'... :D
The battery is fubar'd, so that's on the list, but might whip one off another bike to see if it'll fire up. But that'll be a job for a day when there's more than just 15 minutes or so spare...
gray
#19 PostAuthor: gray » Wed Nov 08, 2023 7:34 pm
doesn't need to fire up to do a compression test , just has to be turned over fast by the battery (with throttle wide open).
If compression is OK then try firing it up and see how it sounds
gray
#20 PostAuthor: warren3200gt » Wed Nov 08, 2023 7:53 pm
It does if you want any meaning full readings. Compression test on a 650 should be 160psi plus HOT.
They'll run fine at about 120psi cold but anything below that it'll smoke and pressurise the gearbox and pump oil out the breather.
I even got a 650 to run with 80psi on 2 & 3 90 psi on 1 & 4. Smoked like a over oiled 2 stroke and would only start in warm weather :lol:
MDM
#21 PostAuthor: MDM » Tue Dec 05, 2023 3:51 pm
With a bit of part-swapping going on between projects, I have a set of GSX-R 1000K4 forks spare, along with a K4 bottom yoke and a one-off top yoke.
The forks and wheel in the bike when I got it were, I think, GSX 600F, and they're okay for a 650cc Zed, but given that I have the other stuff... well... you know...
The GSX-R bottom yoke has the original stem, but it is 20mm too short, so I'm going to cut it across the middle, get a mate to spin up a stepped slug to suit (with a decent length inside each half or the original stem) and get another mate to weld it all together...
olnmfc
#22 PostAuthor: olnmfc » Tue Dec 12, 2023 4:47 pm
How did this 650 turn out? It looks like my cup of tea :wink:
MDM
#23 PostAuthor: MDM » Fri Jan 26, 2024 11:48 am
olnmfc wrote:How did this 650 turn out? It looks like my cup of tea :wink:
Turn out? Gimme chance, not even put a battery to it yet... :D :D :D
MDM
#24 PostAuthor: MDM » Fri Jan 26, 2024 11:50 am
As usual, I'm not prioritising things like checking the engine's condition (there is an alternative if it's junk...) but I wanted to tidy up my garage by using some spare parts I had laying around, so got the GSX-R 1000K4 bottom yoke sorted with a 20mm spacer welded into the stem...
