Brake bleeding - air lock?
RussG
Re: Brake bleeding - air lock?
#16 PostAuthor: RussG » Sun Jun 18, 2023 5:09 pm
compo z1r wrote:
RussG wrote:How do you tell if the master cylinder is the correct size? I’ve never seen them advertised by size …
never had a rex but looks like standard 5/8ths
They are described as 7/8” clutch and brake levers but were cheap eBay ones and don’t specify single or twin disc in the description, wondering if I shouldn’t just buy another one from Z-Power that does say it’s for twin discs just don’t know if it’ll fix it…
Z650C2, B1, F1, ZX9R, Z1000A1
RussG
#17 PostAuthor: RussG » Sun Jun 18, 2023 8:33 pm
They’re 7/8ths apparently, cheap off eBay though and doesn’t say whether it’s suitable for twin discs, thinking I should perhaps fork out for one from Z-Power just to be sure…
floydsz1
#18 PostAuthor: floydsz1 » Mon Jun 19, 2023 11:15 am
If you change a z1 to twin disc you have to fit a bigger bore mastercylinder because it needs to push more fluid due to there being 2 calipers (more pistons) to move. You can buy various size Brembo mastercylinders (for example) depending on what calipers you are wanting to fit and what sort off feel you want.
Z1b,
zxr750 m2,
zrx1200
Z1000j lawson race bike,
Versys 1000gt (2019),
RussG
#19 PostAuthor: RussG » Sat Jul 01, 2023 1:02 pm
So, just wanted to let you know the bigger master cylinder from Z-Power did the trick, did the back brake today as well and alls good, thanks chaps :D
