Fried coil
z1bnackerkwacker
Re: Fried coil
#16 PostAuthor: z1bnackerkwacker » Sun Jun 11, 2023 9:01 am
r3sc wrote:z1bman is correct and it should be the brake light failure module but just double check as that unit should have a small rectangular connector block with 3 wires in it, not 2.
Hope it all goes well!
Sounds like it.
Wasn’t present on my last Zed.
Only have 2 electrical issues left need to sort earths on both front indicators, checked and working with separate wire and stop light on clock is stuck on, still not connected to wires in headlamp as it’s been chopped and there’s no blue to connect to so haddened figured out yet.
Suppose you could help.
What two colours does front bake switch connect to in headlamp.
I’ve got a pic but can never shrink them to fit this site.
z1bnackerkwacker
Re: Fried coil
#17 PostAuthor: z1bnackerkwacker » Sun Jun 11, 2023 9:03 am
Hope it all goes well![/quote]
Sounds like it. Poss was 3, seen so many wires over last few days I dream ohms.
z1bnackerkwacker
Re: Fried coil
#18 PostAuthor: z1bnackerkwacker » Sun Jun 11, 2023 9:07 am
Sounds like it.
What two colours does front brake switch connect to in headlamp :?:
Re: Fried coil
#19 PostAuthor: z1bman » Sun Jun 11, 2023 11:56 am
Front brake light connections are brown & blue . brake failure relay has three wires yellow black & green with white stripe
Users browsing this forum: Stugill and 73 guests
