and yet another bloody Lawson......
martinz1000r
#16 PostAuthor: martinz1000r » Mon Sep 15, 2008 4:06 pm
Crankcases back together, sump on and ready to slot in to the frame! So glad I took loads of pictures of the selector forks etc on gearbox or it would never have gone back in the same way.
The most surprising thing was that I had no bits left over when everything was built :D . Very unlike me! Even when I used to put aeroplanes together I never felt completely happy unless i had 1 or 2 bolts left over after an engine change :oops:
Anyone local to Faringdon that can lend me some piston ring compressors? If not old plastic bottles and tie wraps here i come......
martinz1000r
#17 PostAuthor: martinz1000r » Sun Oct 12, 2008 5:22 pm
Got my barrels on and starting to see some real progress until we hit a problem with a replacement rotor and the starter clutch.
Whilst I try and sort a solution to the broken rotor I thought I would loosely assemble everything lurking around the garage just to see what the finished bike might look like. I was pretty pleased with the result and hopefully will give me the inspiration to push on and get it finished before next spring. Interested to know what people think??
Still loads to do but some light at the end of the tunnel now :D
#18 PostAuthor: Pigford » Sun Oct 12, 2008 5:58 pm
Looking really good... espescially in the SUNSHINE :lol:
You gonna run it with the bell mouths (no filter) :?:
Pasc
#19 PostAuthor: Pasc » Sun Oct 12, 2008 6:14 pm
Looking good Martin. Looks very tidy.
Now crack on and get it finished :lol:
martinz1000r
#20 PostAuthor: martinz1000r » Sun Oct 12, 2008 6:17 pm
Probably not for road use! Might be interesting to see if it will hoover up the kids or the cats etc but I have a set of K&N's lurking in the garage. Given the investment to date in that engine it would be a shame to blow it with no filters.
martinz1000r
#21 PostAuthor: martinz1000r » Sun Apr 05, 2009 2:41 pm
The sun is shining so thought i might invest some time in the bike. Just realised that moving my pictures around my photobox accounts has lost the links to all the pictures so will re-do some.
Anyway wish I had not started now as when I came to tighten down the cam holders I found 3 of the holes have stripped threads and wont tighten down. This after all the money on gas flowing, valves etc :cry:
Best get on eBay for a helicoiling set and try again. They must have been glued in with loctite as I cant remember any issues when i took them off.
Will post some new photos later.
Robw
#22 PostAuthor: Robw » Sun Apr 05, 2009 7:26 pm
Martin, I had exactly the same problem when I tightened my cam caps down, something like 4 threads stripped. I got my helicoil kit from Unithread, who I recomend (01803 867832).
Rob
#23 PostAuthor: Ginger Bear » Mon Apr 06, 2009 6:25 am
Martin, just read this whole thread, sounds fantastic...... just can't wait to see it with pictures!!
martinz1000r
#24 PostAuthor: martinz1000r » Tue Apr 14, 2009 7:25 am
one step forward, 2 back over the weekend. Bought the helicoil kit from Uni-threads as recommended by Robw. Great service and advice but found I need to remove the head again to drill out the holes. My old man who is wise on such things recommended I did all the holes whilst it is off so back on phone to Unithreads this morning as the kit only comes with 8 coils and I need 16. Also need to find machine shop round here to get holes drilled accurately by someone with a pillar drill. He says my Black and Decker is not recommended...
Question for the experts on the head gasket... :?: :?:
Should I fit a new one? Head was correctly torqued down before it was removed but engine never run. Do i need to buy another new head gasket or am I ok using the same one??
martinz1000r
#25 PostAuthor: martinz1000r » Tue Apr 14, 2009 1:50 pm
Here is some of the pictures back....
The original bike:
Looked nice and shiny but under the surface.....
as we start to come together:
and roughly assembled to see what it is going to look like:
Still loads to do but limping ever closer to completion!
Pasc
#26 PostAuthor: Pasc » Tue Apr 14, 2009 1:56 pm
Ooh nice, suits you Sir.
#27 PostAuthor: Pigford » Tue Apr 14, 2009 6:21 pm
I'd re use the head gasket if you haven't run it :wink:
But, there is always a slight possibility it may weep :?? But at about £50 for a decent Cometic, worth a punt :shock:
Looks really nice by the way :twisted:
#28 PostAuthor: paul doran » Tue Apr 14, 2009 10:14 pm
lovely ELR :lol: :lol: :lol: :lol:
kano
#29 PostAuthor: kano » Wed Apr 15, 2009 12:32 am
looking good
i live free and ride in the states but i am British and bloody proud of it!
http://www.kz1000r.com/
martinz1000r
#30 PostAuthor: martinz1000r » Wed Jun 03, 2009 10:57 am
Time for a quick update and pictures will be posted when I find where my wife has hidden the camera.
Engine rebuilt but using original cams after the issues with the Web ones. Filled it with oil and some minor leaks but a bit of bolt tightening seems to have done the trick. Put the battery on charge all weekend and then disaster!!!
Had the bike on axle stands to sort out front wheel spacing and I managed to drop it as I took it off the stands. Ignition cover smashed and brand new Kerker dented and very hurt pride. Copious swearing and a few tears :cry:
Battery slotted in, reconnected, petrol in tank, turn ignition on, pressed starter button and......
nothing.......
either battery f**ked or not earthing where copious plastic coating applied. Out with multi-meter next weekend to trace problems.
Also cant get brakes sorted. The pads supplied by Norman Hyde for my AP calipers are too thick. I can squeeze in pads but not pads and discs so think they might be wrong. Also hydraulic clutch conversion I had made is leaking and I cant find the nut that holds gearbox end sprocket on.
Oh joy!
Pictures to follow as it does look smart.....
Users browsing this forum: j.wilson and 128 guests
