Spark Plugs
bigmac103
#16 PostAuthor: bigmac103 » Sun Jan 25, 2009 3:50 pm
I checked out the link Chrisu posted and tested my coils, found only 7 volts getting to them. So I did some fiddling with the wiring and rewired the coils as per diagram and problem solved. Thanks Chris :brav
Lost in the desert somewhere
oldzed
#17 PostAuthor: oldzed » Sun Jan 25, 2009 4:47 pm
As an aside If you are using a standard relay you should think of replacing it with a relay with diode protection.
see http://www.vehicle-wiring-products.eu/V ... relays.php
bigmac103
#18 PostAuthor: bigmac103 » Sun Jan 25, 2009 6:09 pm
Thanks oldzed, do you know any shops that do the socket with pigtails?
