front caliper bleed nipple sheared.
dave3d
#16 PostAuthor: dave3d » Fri Feb 20, 2009 12:09 pm
wow, sounds like a quite a few options... thanks a mill everyone. I'll start slow and easy ' like you say, plenty of time as the carbs are off
cheers
Dave
#17 PostAuthor: Al » Fri Feb 20, 2009 11:45 pm
If the nipple has sheared off flush with the machined face of the caliper you can weld a nut onto the end of it. An 8mm nut will have an internal diameter sufficiently big enough to mig-weld straight through the middle and when its still at red heat and after maybe a half a minute or so put a spanner on and turn it slowly. Not too hot and not too soon but the heat transfer will aid removal.
