High speed/revs splutter
bigmac103
#16 PostAuthor: bigmac103 » Fri Apr 03, 2009 7:39 am
Mikey, I think that's your problem too.
Lost in the desert somewhere
mikey
#17 PostAuthor: mikey » Fri Apr 03, 2009 10:52 am
Thanks guys i will check it out over the weekend and try everything suggested.
mikey
#18 PostAuthor: mikey » Sun Apr 05, 2009 3:42 pm
Right this is what i done, before i started on the problem at hand i had an oil leak out the cam cover so thought id do that first, while the cam cover was off thought id check the valve clearences, 2 were tight so i done those, first i checked the ignition side of things and all seemed ok there nice bright blue sparks at plugs, but the bullet connectors to the coils were a bit slack so just nipped them up a bit to make more solid connection, checked the voltage to the coils and that checked out ok.
So to the fuel side of things, checked the fuel cap first as rich suggested the breather hole maybe blocked and as i had it re chromed recently i may have put it back together wrong but it checked out ok, fuel tap next, pulled the 2 fuel pipes off put it on prime and fuel was only coming out of only 1 of the out lets, stripped tap apart and found water in the tap how it got there i dont know, blew it out and dried it and filled it filled with fuel put it on prime and fuel flowed from both out lets, tlc suggested just draining the bowls and should be ok but for my own piece of mind i stripped the carbs and blew the jets through found a couple worn needle valves and replaced those from my box of bits, swilled the tank out and put fresh fuel in, put it all back together fired it up took it for a run and now it accelerates all the way to the red line without spluttering problem solved took a while but i guess a problem like this is a process of elimination, thanks everyone for your help happy days again.
#19 PostAuthor: chrisu » Sun Apr 05, 2009 4:08 pm
excellent news mikey
looking forward to seeing you revitalised Z at the Ace.......
mikey
#20 PostAuthor: mikey » Sun Apr 05, 2009 4:16 pm
Cheers chris wouldve took the speed triple but now the Zs sorted dont have to.
bigmac103
#21 PostAuthor: bigmac103 » Sun Apr 05, 2009 5:00 pm
If the tank was left half empty for a while, i.e. over the winter then that would explain the water. Glad your sorted Mikey.
mikey
#22 PostAuthor: mikey » Sun Apr 05, 2009 5:13 pm
It was a 2nd hand tank that was sourced for me after the rear end shunt i had and the first i saw the tank was when it came back from the painters so i dont know the history of it bigmac but you could be right there.
#23 PostAuthor: Rich » Sun Apr 05, 2009 6:15 pm
You will always get a small amount of moisture in fuel, blast it up yo the red line frequently to stop it building up :D
mikey
#24 PostAuthor: mikey » Sun Apr 05, 2009 6:17 pm
Ok cheers rich thanks for the heads up on that.
mikey
#25 PostAuthor: mikey » Mon Apr 06, 2009 2:33 pm
Spoke way to soon got on it today and the fcuking thing wouldnt even start took the plugs out they were black and wet checked for a spark thats ok at that point i lost intrest and pushed it back in the garage and jumped on me speed triple, could the carbs just simply be worn out and want overhauling.
Mark Stratton
#26 PostAuthor: Mark Stratton » Mon Apr 06, 2009 2:37 pm
I sympathise with you Mikey thats the way I feel at the moment!!!!!!!! :(
mikey
#27 PostAuthor: mikey » Mon Apr 06, 2009 2:43 pm
Realy pisses you off at times dont it mark just going out to the garage now to either start trying to fix it or kick it off the stand and kick the shit out of it.
Mark Stratton
#28 PostAuthor: Mark Stratton » Mon Apr 06, 2009 4:07 pm
It's time's like this that I start to look at the Bike Trader and the modern Z1000's!!!!!!!!
#29 PostAuthor: Rich » Mon Apr 06, 2009 6:28 pm
It's times like that that you sit down and have a nice cold beer and leave the bike well alone, Things don't cost as much when you've had a chance to to think about them.:wink:
When did it last work right?
What have you done since then?
ted1r
post
#30 PostAuthor: ted1r » Mon Apr 06, 2009 7:02 pm
Its times like this I ring somebody Coz I know F all ,Bit like that with mine at the mo Mikey mate.
Ted
"Work this is why I did it"
KE250
KZ1200
Puch Maxi
Be careful with Pensions :e
and me ol Granada
