The other has a Philips head bolt.
and air / impact drill
was required
doebag wrote:If it is important to you, the fender bolts are 8mm x 16mm with 12mm head, with spring washers below.
The drain bolts are 4mm x 8mm long with cross head, with gasket [copper washer?] below.
Steve Cooke wrote:Is it the bush that's missing? if so what are the dimensions as I have an odd one here from an A4 you can have but not sure if the size is the same.
