GB's Modded Z900 now on a runaway budget!
- Ginger Bear
- Ginger Bear
- Ginger Bear
Is Vic There
- Ginger Bear
wilsonsjw11
- Ginger Bear
- Ginger Bear
Today's update from the Buzzworks.
"Cylinder head on jig at correct angle on milling machine and lined up on valve guide casting hole using an 12mm arbor to make sure boring head is positioned concentric to valve seat. Valve seat throat is then machined to remove the ridge between seat and head casting. Some early heads which are poorly cast can have upto a 1mm lip/ ridge which is not good for decent flow. Buzz@buzzworkz"
- Ginger Bear
The last couple of weeks have proved to be extremely busy work wise, so progress has been slow.
What I have managed though, is to strip the original motor, which from the outside looks quite unassuming.
I had the head off last week & was delighted to find these little beasties inside.
Things got even better when I flipped over the head.
Although I've not stripped this any further, just packed it away for a rainy day.
I had wondered if there was any exotica waiting for me in the bottom end, but after today's efforts I can only report two snapped 6mm crankcase bolts which have drilled out successfully & one drill or tap snapped off in one of the sprocket cover bolt holes by a previous owner.
I'll get the offending case up to Bowden Auto Engineering to have the little bastard spark eroded, before they go to Griffs to be powdercoated.
