Pigfords OLD effort......now JULES NEW PROJECT!!!!!
#256 PostAuthor: Pigford » Sun May 24, 2009 8:39 pm
Thanx to Al (Zorded) - I have finally managed to degree me cams in :o
Al loaned me his 'top guide deflection tool' so I could check the inlet cam. As it happens, when this was fitted, it only altered the timing by a few degs.
Anyhow, the engines all back together & running.... but the f**ker still tends to hang up on the revs :cry: :?? :evil:
The carbs are a bit out so will haved to spend yet more time fiddling :!:
I checked the inlet rubbers (sprayed duck oil on them whilst running) and don't seem to be leaking.
Double checked the timing - was a bit retarded (33 degs BTDC) so set to 38degs.
Last resort will be to try another (standard) head & cams...... :??
Gotta concerntrate on the Trumpet first coz its due for MOT 6 June :shock:
#257 PostAuthor: Ginger Bear » Sun May 24, 2009 9:38 pm
Piggy...... Wot a pi**er.
Dodgy Z1B
#258 PostAuthor: Dodgy Z1B » Sun May 24, 2009 9:40 pm
Got to be carbs for sure, not got any1 with a dyno near you to check it out.
#259 PostAuthor: Pigford » Mon May 25, 2009 7:52 am
Dodgy............... But I tried some RFS36's carbs off me black Z1000, which were OK, but it did the same thing when fitted on this b*gg*r.... :??
Been suggested it could be a hairline crack in me head :shock:
Hoooo Hummmm..... down to me mate now - Percy Veerance :roll:
mick znone
#260 PostAuthor: mick znone » Mon May 25, 2009 8:01 am
sorry to hear that Piggy, hope its not costly :o
Padders
#261 PostAuthor: Padders » Mon May 25, 2009 8:13 am
Keep at it Mark I am sure you will get there. Remember you have that lovely Triumph to pop out on and take your mind off the problems. Lucky ba**ard.
#262 PostAuthor: Pigford » Sat Aug 15, 2009 4:23 pm
OK.... been having a bit of a fiddle again... :??
The cams are degreed in OK (both about 108/109).......
I have checked the Dyna S & bob weight springs (nice & tight) and ran the bike up....
Still HANGING UP on the revs...... Tried the RS38's & some std 34mm CV's...
The engine is NOT fully warmed up & the carbs are standard jetting (I think) - but it still started up fairly well..... even without the air box, which is surprising for gripey CV carbs :|
Rubbers don't leak... throttle cable loose & returns OK.....
My thought now is:
The cams (still unknown make) are a bit lumpy & they may be over lapping too much (or sumink) as the carbs do seem to be spitting fuel back. This means that even though the idle seems low - its the cams struggling to keep the idle, so when you blip the throttle, the revs pick up, the motors running nicely and gas is flowing at a more optimum mix... so the revs catch & hold high :?: :evil: :evil: :?? :?? :shock: :shock:
#263 PostAuthor: Ginger Bear » Sat Aug 15, 2009 7:21 pm
Piggy, I have a set of standard GPz cams you can borrow if you want.
#264 PostAuthor: Pigford » Sun Aug 16, 2009 8:45 am
Thanks GB.................. May well have to try that route, I suppose :cry:
Gonna have a little think about the whole situation, before I wheel it down to the local tip :??
#265 PostAuthor: chrisNI » Sun Aug 16, 2009 10:22 am
Pigford wrote:Thanks GB.................. May well have to try that route, I suppose :cry:
Pigford I have just been reading this whole thing - I understand you don't know what the cams that are in it are is that right so you have really no idea what they should be timed at. I think a set of standard cams or at least a set of cams that you have a figure for is a lot better of an idea than a trip to the tip.
hillbilly
#266 PostAuthor: hillbilly » Sun Aug 16, 2009 1:34 pm
pigford ,just as a question,is the barrels and head off a gpz1100.
#267 PostAuthor: Pigford » Sun Aug 16, 2009 2:36 pm
Barrels off a Uni-track, head I think is the original ELR, but gas flowed.
Main thing is compression ratio is Ok ( 10.24 : 1 ) and compression good.
london calling
#268 PostAuthor: london calling » Sun Aug 16, 2009 3:56 pm
Piggy stick to what you know best :wink:
Get one of these little beauties and IRON out any problems you're having :lol: :lol:
Jack
hillbilly
#269 PostAuthor: hillbilly » Sun Aug 16, 2009 4:08 pm
even a small crack in the head wunt have that effect,maybe the cams have been ground wrong, :?: ide try 36 carbs with standard cams, :wink: at 1260 you can get some larger cams to suit,once its behaving. :wink:
#270 PostAuthor: Pigford » Sun Aug 16, 2009 4:42 pm
Hillbilly..... its only 1170..... :| And have tried the RFS36's off me black Z1000 (which work OK on that) but on the Lawson - same thing :evil:
next is try different cams.... Also got a spare standard head in reserve :!:
Users browsing this forum: deka and 34 guests
