Surprise Piston's........ Any Idea's Please?
Steve R
#31 PostAuthor: Steve R » Thu Nov 19, 2009 2:14 pm
Hi Bear,
Lucky you!! Makes a change to find it as clean as that when you pull the head.
I am running 10.25 to 1 1075 cc on my Z1A with no problem at all, thought I may have to use an octane booster but does not seem to be required. The only potential problem is the starter motor struggles a bit, however with Dyna coils and elec ign it fires very quick.
Pasc
#32 PostAuthor: Pasc » Thu Nov 19, 2009 8:53 pm
Bear, here's where you want to be. http://www.750turbo.com/forum/viewforum.php?f=13
The 750 Turbo and the 1100 DFI systems are very similar systems bar a few extras such as boost sensor, so you should be able to use the info on the site to set one up. I wouldn't usually suggest this route to sort things out but second hand Power Commanders are cheap as chips these days. Wire one in, spend a couple of hours on the Dyno (with a good operator) and Bobs your weird uncle your mom never left you alone with :lol:
Oh yes, one other thing,. If people continue to refer to the best bike Kwak ever made as a GPz750 Turbo then I won't be responsible for my actions :club
IT'S A Z750 TURBO. OK ? :D
#33 PostAuthor: Ginger Bear » Thu Nov 19, 2009 10:12 pm
Thanks for your input guys. I had planned my next project to have a sensible budget & just try & use what I already have, which does include 3 complete fuel injection systems :shock: And of course this recently discovered 1170 kit :D
I must say, the Jury is well & truely out on this one now. I did have a dabble on the 750Turbo site this afternoon, but had to leave as my brain started to fade :roll:
I like the simplicity & performance of flatslides, but they don't come cheap :cry:
