Engine rebuild
tlc
#31 PostAuthor: tlc » Tue Mar 02, 2010 5:58 pm
The o rings arrived today as well as the fake Kawabond so I`m ready for crankcase reassembly as soon as Mikey sends the case bolts.
I spoke to Dogs yesterday and he said the head should be ready for collection on Friday. However.....................
When Doug Cox blasted the head they did not blank off the guides and contaminated them. Cross............bloody right. We`ll see what he says about that to him as he was told we would be using them and 1 had been replaced as worn anyway. So that`s another £80 on new guides then :|
GEZ635
#32 PostAuthor: GEZ635 » Tue Mar 02, 2010 8:15 pm
Well done so far. I am not a believer in vapour blasting as I have said many times. However, I just cant get why this guy some of you use to do your blasting does not blank of any threads etc. Plastic insert bungs cost pennies and someone(maybe an angry you!!) should tell him, if he wants to continue offering this service he should do it right. I saw your pics of you cleaning out your threads and you should not have to do that.Imagine if you miss any grit and it gets in your oil! I think that would be called grinding paste!. Have you ever tried valve guide inserts? Fantastic alternative,out last original guides by years and no need to re-cut seats afterwards. Total cost is about £120 per cylinder head.
Gez
Crofty
#33 PostAuthor: Crofty » Tue Mar 02, 2010 8:15 pm
That's a pity Chris, still, if you replace them now, it's done. Had you had the one replaced at the beginning of this rebuild or previously? You seem to be moving pretty quickly on your rebuild.
tlc
#34 PostAuthor: tlc » Tue Mar 02, 2010 8:29 pm
I entrusted the head work to Dogs because he has the experience and the contacts.
I am disappointed and surprised as Cox`s do lots of this work and should have followed instructions. We`ll see what they say !
Gez. I remember years ago when CMM had an early form of blasting done by a local company and their CBX motor lasted less than 50 miles before it self destructed. They reckoned the ultrasonic effect dislodged bits from the cases but after talking to Maine I felt confident that I could clear all the rubbish.
How else would you clean brush painted hammerite from cases ?
Crofty. This is taking a frustrating amount of time as the motor has been sitting on the bench for an inordinate amount of time and the sun has begun to shine :cry:
Steve S
#35 PostAuthor: Steve S » Tue Mar 02, 2010 9:02 pm
Hang in there Chris you will soon be up and running,sorry to hear about the head issues,hope you get it sorted. :D
Crofty
#36 PostAuthor: Crofty » Wed Mar 03, 2010 10:15 am
Hi Chris, i'm relatively new to blasting and media type cleaning of engine parts. Just wondered what it takes to contaminate the valve guides and why they need replacing? Jim
tlc
#37 PostAuthor: tlc » Wed Mar 03, 2010 5:26 pm
There is a medium contained within water which is blasted at very high pressure.
A bit like sand blasting but less severe.
Sadly severe enough to mark the guides. I have not seen the head yet but it is with an engineering company who are trustworthy and if they say they are damaged then......................
Davy Doherty
#38 PostAuthor: Davy Doherty » Wed Mar 03, 2010 9:29 pm
Bummer Chris, but i'm sure you can handle the flak..
GEZ635
#39 PostAuthor: GEZ635 » Wed Mar 03, 2010 11:24 pm
soda blasting is very good and leaves a more natural finish to the aluminium, and just washes off. You can also get the engine nice and shiney after blasting if thats your thing. Gerry,our President saw some I had done and has now had his engine done so hopefully he will post some pictures soon. Soda is a much safer option in my opinion with no risk involved and very cheap.
Gez
tlc
#40 PostAuthor: tlc » Thu Mar 04, 2010 6:19 am
I wonder if it`s something like that they use ?
When I was cleaning out threads with the bottle brush I thought the bristles were breaking off as what came out was translucent white !
wilsonsjw11
#41 PostAuthor: wilsonsjw11 » Thu Mar 04, 2010 8:20 am
Chris
Just fit new guides all round its done then,you don't want to be lifting the head off again for a while.
Bite the bullet ring Debbens and order some APE guides don't scrimp,you want to see the bill for parts for the engine rebuild for the 73 Z1 its FRIGHTENING :shock: :shock:
I've had to delay buying the new range cooker for the wifes new kitchen :lol:
tlc
#42 PostAuthor: tlc » Mon Mar 08, 2010 8:12 pm
I got the bolts from Mikey today and fitted the cases together. The Z Power gasket stuff worked well and I just wiped off the admittedly small amount of excess with brake cleaner.
I nearly forgot about the oil bypass ball and spring thingy :oops: but it all went together okay.
Off to Dogs at the weekend to fit the barrels and collect the head.
Things are looking good and I`m a lot more confident of being done soon. When the barrels are on Maine said he`ll help me to lift the motor in.
tlc
#43 PostAuthor: tlc » Tue Mar 09, 2010 6:55 pm
Latest pics.
Just waiting for some dowels from Z Power and I can get on with finishing :D
#44 PostAuthor: Pigford » Tue Mar 09, 2010 7:28 pm
Looking super squeaky clean.... :wink:
sp.milne
#45 PostAuthor: sp.milne » Fri Mar 12, 2010 4:44 pm
looking good chris i hope you cleaned it out properly :lol:
Users browsing this forum: j.wilson and 170 guests
