New Project 2011/2012 /2013/2014!!
z1000puddin
#31 PostAuthor: z1000puddin » Sun Dec 09, 2012 11:35 pm
Started on the first fix of electrics yesterday.This bit I was dreading as me & electrics don't mix.
After about 4 hours of trying to get a reading at my ignition white wire, I finally found the fault, which was a bad connection inside one of the connector blocks.
Now all working, lights front & rear - clocks, starter all good.
Also fitted the venhill brake & hydraulic clutch lines & will bleed these next week.
Some pics of the loom "mess"- I have ordered some stainless steel / pvc coated cable wraps to tidy it all up.
I should also have my stainless steel battery box fabricated at work next couple of days.
Zed til Dead
z1000puddin
ITS ALIVE !!!!!
#32 PostAuthor: z1000puddin » Wed Dec 12, 2012 9:05 pm
Well decided to stick some oil into the engine.
Roughly fitted the 28mm carbs.& some old throttle cables.
Whipped the tank off of my other zed.,,,,,,..........................
:evil: :evil:
SHAGGED THE WOODRUFF KEY AFTER ABOUT 5 SHORT BURSTS :evil: :evil:
So I decided to kick start the bloody thing --- Worst decision ever !!
Dont try to kick start a zed while wearing your slippers :oops:
The bloody thing kicked back after 2 kicks & promptly ripped through the side of me slipper :??
Opened the side from toe to heel - Bloody sore that :x
After putting my boots on,I gave it another kick & she started up straight away.
Sounds a little bit rough, but I have only static set the ignition & the carbs are still to be fitted with some velocity stacks & possibly need set up.
But here is a little "JERKY" video.
I only revved her up to around 3000 revs & still on half choke.
But it is a very GOOOD feeling after having this kicking about the garage in bits for the last year & a bit. To actually have her running is a great feelin.
stu
Zed til Dead
mikey
#33 PostAuthor: mikey » Wed Dec 12, 2012 9:51 pm
Bet that was a buzz to hear it running stu
dont sound half bad either
z1000puddin
#34 PostAuthor: z1000puddin » Wed Dec 12, 2012 10:13 pm
Mikey,
Yeah bloody good feelin.
I need to strip off the carbs again, as I cannot remember what jets / settings these were set up with, but they ran okay on the 1000ltd I had.
I will also be sending down an alloy chain guard , the front brake/ clutch levers & the rear number plate mount for some MEG ( Mikey Elbow Grease) :P
Again, no mad panic for these bits to come back as I wont have the paint set back from Si (flying tiger)until late January.
Will PM you nearer time
Zed til Dead
ollie
#35 PostAuthor: ollie » Wed Dec 12, 2012 11:43 pm
nice one stu :brav :hoo ,its a terrific feeling ,well done ,hope slippers are on santas list :lol:
z1000puddin
#36 PostAuthor: z1000puddin » Sat Dec 15, 2012 5:59 pm
Took the bike out into the sunlight toady, Si can get a feel for the paint work.
Some pics ( the 4-1 collector is drooping a bit, That will get sorted once I have the link/tail pipe done)
Still to do..
Bleed brakes & clutch
Fit rear sets
Fit velocity stacks
fit new throttle cables
Sort out exhaust
Fit rear exhaust outlet cover plates
Fit battery box front support plate
Tidy & fit cables/ hose clips.
Stu
Zed til Dead
#37 PostAuthor: Pigford » Sat Dec 15, 2012 6:43 pm
Cracking :twisted: And love that seat :!:
Mr Puffin
#38 PostAuthor: Mr Puffin » Sat Dec 15, 2012 7:34 pm
that Looks really good puddin :twisted:
Might be an idea to chop those rear footrest hangers off though :wink:
z1000puddin
#39 PostAuthor: z1000puddin » Sat Dec 15, 2012 7:56 pm
Thanks guys,
The seat was made of 3mm ally & fabricated at work.
I had a local guy up in Aberdeen mould the foam & covered in it leather.
It took him a couple of goes to get the shape/ look that I wanted, but I am happy with it now.
Mr Puffin,
My idea on this project was to have a standard z1000 frame & not molest it.
I could have went the whole hog & braced it/chopped it etc, but,this could be put back to standard if required.
All the "Bits" are made to bolt on.
This idea of mine has caused all sorts of issues that I have had to overcome & sometimes I thought " Is it worth it"
But I beleive that once you start a project with an idea that you need to stick to it.
I hope I have made the right choice !! :!: :!:
The rear sets actually pivot from the bottom of the rear foot rest hangers.
They are quite comfortable for me ( 6ft 4") But maybe not to everyone's fit position.
The comments are more than welcome guys.
Stu
Zed til Dead
mikey
#40 PostAuthor: mikey » Sun Dec 16, 2012 10:28 am
Looking good stu,
well ive never been called MEG before :lol:
z1000puddin
#41 PostAuthor: z1000puddin » Sun Dec 16, 2012 2:06 pm
Guys,
Spent the morning bleeding the Falk hydraulic clutch.
Question is - How or is there any adjustment on these, I thought that they were self adjusting :?:
With mine all bled & fitted I dont get any back wheel movement when engaging the gears :?:
With the clutch casing off, I get all my gears ( just knocking it to gear)
The Falk slave cylinder seems to be working fine with the casing off.
I am using a GPZ900 master cylinder
It seems as though my clutch is engage all the time, when the casing is on & bolted up :?:
Do I need to shorten the clutch push rod ??
Any pointers greatly accepted
Stu :|
Zed til Dead
#42 PostAuthor: Ginger Bear » Sun Dec 16, 2012 2:37 pm
Stu, I have a vague memory that I had to shorten my pushrod.:oops: :?? Just get someone else to confirm it before you get the grinder out.
#43 PostAuthor: Pigford » Sun Dec 16, 2012 4:12 pm
The unit comes with a small bit of bar inside where the rod sits. You just cut that to length.... I didn't find a lot of "self adjustment" with mine :|
z1000puddin
#44 PostAuthor: z1000puddin » Sun Dec 16, 2012 5:56 pm
Thanks gents,
I did think I would have the cut the push-rod down.
I didn't get any bar with the unit, but if I do get the length wrong, I can get a small bar machined up, possibly thread it into the slave cylinder so I do have some adjustment.
Stu
Zed til Dead
z1000puddin
#45 PostAuthor: z1000puddin » Mon Dec 17, 2012 10:27 pm
Its going to be TIGHT.But it will fit :shock:
Tacked up the rear baffle box & tail pipes.
Just need to get the link pipe sized up & send the details down to Dave.(Exhaust craft) So I can join everything up.
Removed the tail & will get these down to Si this week.(flying tiger)
Clutch now sorted
Front & rear brakes were a doddle to bleed, Very unusual.
Found out that the generator coil & the original regulator were goosed, so I have ordered up both from Electrexworld.
So I will also have to get another alternator cover gasket :roll:
Zed til Dead
