zman wrote:Nick a bit frustrating but its your bikes way of building a bond between you both![]()
Hi David, you are not wrong! - just want to get on & enjoy riding it really.
zman wrote:I would worry more about the rain.![]()
Garn 1 wrote:I think it is very hard to check end-float of either cam-shaft, unless it assembled up without valve springs as an initial check. The pressure of the springs, buckets and shims on the cams makes it extremely difficult to get a real feel.
I have noticed (I have said this elsewhere) that there is definite "Clonk" noise when lifting a head from one place to another when camshafts are assembled without the above spring assembly pressure. I have seen on several "strip-downs", small punch-marks on the thrust bearing, which has obviously been an attempt to reduce this end-float.
Also, I have experienced an oil blockage in one side of the cam-shaft (thrust side) where I could not blast air down the head cam-shaft bearing to the stud hole. I had a blockage in the diagonal valley (oil-way) between the bearing and oil source.
RegardZ.
njwmct wrote:Got a problem with my Z1000 Mark 2.
It's a low mileage motor at 6200 miles.
There is a noise that appears to be coming from the top end of the motor.
It's most evident at idle when the motor is cold - hard to describe but the noise comes & goes.
It's not a rattle like a camchain & it's not a heavy knock - it's more of an intermitent clanging noise.
The noise lessens when the motor has warmed up but it's still there slightly from time to time.
I had the alternator cover off to check that the rotor was tight & it was.
I will have a look under the camcover tomorrow.
Just wondered if anyone has experienced a similar thing?
Users browsing this forum: Google [Bot] and 101 guests
