Top shock mount extensions
Re: Top shock mount extensions
Hi Stempy - sorry dumb question. What advantage do the extensions give ? Wider choice of shocks ? Different swinging arms ? Thought if I don't ask I'd never know
Present
Red '78 KZ - rebuilt from engine up
Other wheels - Couple of old Guzzi's
Past 1994 - 2010
Luminous Green '78 KZ import [BLE 656S]
Past 1994 - 2010
If you fit a wider swing arm the lower shock mounts are moved further apart . These move the top shock mount out to compensate .
fer
fer
Any chance you have a set knocking about, if not will you be making any more?
Foz
Foz
If you do, i will have them off you, PM me you payment details.
foz
foz
Will you be making any more of these ? I have a set of 20mm but could do with 25's
Anyone interested in the Shocker mount extensions ,ready to start another batch should be ready next weekend .
Stempy
Stempy
PUM 451
I will have a set please, have sent you a pm , thanks richard
I am interested, but is it possible to get a shorter set made up. Basically I need a set that just extends by maybe 25mm over the stock set up, or roughly the length of threaded portion again along with the back spacer
I have a Zephyr swingarm and its only that much wider each side than stock. I have the long set - but they are too long
Charlie
Normally people fit the 20mm extensions when fitting a ZRX arm ?
Stempy
Stempy
PUM 451
Yeah, mine is a 650, and I have a Zephyr 400 swingarm.
I only need to extend my current frame mounts by 25mm overall, that's the thing mate, not 25mm and then the thread if that makes sense ?
I can get the shocks on with a spacer fitted on the frame side as it sits, but not enough room left on the thread for the grab rail, or even a full nut - its all too close to be comfortable really. I kinda need 10mm of additional extension plus a further 15mm of thread.
A stubby version of what I had last time.
If that isn't doable, no problems
Please can I have a set.
PM sent
PM sent
