GPZ 1100 fork balance tube position
Re: GPZ 1100 fork balance tube position
Sorry, I can't do the measurement as the bike is stripped. There are plenty of others on here with 11 Uni's. Maybe worth doing a new thread specifically for that question in case people aren't following this one.
moizeau wrote:Sorry, I can't do the measurement as the bike is stripped. There are plenty of others on here with 11 Uni's. Maybe worth doing a new thread specifically for that question in case people aren't following this one.
Good point. Thanks.
I'm on holiday until Monday so I can't get the measurement to the centre of the balance tube home till then.
Stu
Stu
Happy to wait stugil.
I’m waiting for gaskets and still need to check shims. Not going anywhere soon
P
P
Phil.
I hung the tang of the tape at the top of the top mount.
It was 230mm to the top of the bottom mount.
It was 270mm to the bottom of the bottom mount.
It was 216mm to the centre of the balance tube.
I hope this helps / makes sense?
If you need anything else please let me know.
Stu
Stu
Stugill wrote:Phil.
Stu
Hi Stu,
Hope you enjoyed the holiday!
You have 230 top to top, I have 249! At least I know where the issue is. I appreciate the time and effort, you, Pete and Hard road put in to reply with pictures and measurements. Hopefully the head will go back on without issues.
Pete.
Yep great warm holiday, not like the very cold weather here!
It's a pleasure mate, good luck with the build.
Stu
Stu
