Steven Cooke wrote:NGK or Denso there both good plugs when they're working and they're both shit when there not, hope that helps.
Nail on the head.........
would it be worth the extra money for iridium plugs?
mikey wrote:Very informative Al thanks for posting that certainly explains a lot of things so in your view would it be worth the extra money for iridium plugs? just this morning fired my Z up and no 2 wasnt firing pulled the plug out gave it a wipe (wet plug) put it back in and all was well again, but probably same thing happen to another plug tomorrow.
AndyZ1R
PostPosted: Tue Jun 09, 2009 10:14 pm Post subject:
I was talking to the guy at Les Smith where i get all my top of the range Harry Moss products, and he says you are ''talking bollocks'' and that ''all you need mate is a good spark plug cleaner made by Ronco, that will sort you out.'' You can get one of their Fuzz-aways to tidy up your tank top and corduroys at the same time (or just borrow mine). I wonder if Ronco do a carb balancer?
There is some pretty good plug info on here by the way, worth a look: http://www.gsparkplug.com/
it may be worth giving them a call to see what they have to say? Apart from ''fuck off Al and stop wasting my time!''
floydsz1 wrote:mikey wrote:Very informative Al thanks for posting that certainly explains a lot of things so in your view would it be worth the extra money for iridium plugs? just this morning fired my Z up and no 2 wasnt firing pulled the plug out gave it a wipe (wet plug) put it back in and all was well again, but probably same thing happen to another plug tomorrow.
mikey,
if it happens again, before you remove the plug just pull the cap off the plug slightly and leave it just resting on the plug tip. see if it starts to fire, after about 30 secs push it back on. If your scared off getting a shock use some pliers, i just get hold off the plug cap if it happens on mine,
